Wasn't that a Bach Choral thing?Or even allude...
The relay switches power supplied to it, to the required lamps, rather than taking power from those lamps and potentially over-loading those lamps circuits. Should also, if you pick the right unit, allow the use of trailers with LED lamps as well as conventional lamps.Why do you need a relay?
It appears to me that the 2x 7 pin sockets fitted previously in the uk(?) have all the wires/feeds that you are needing to tow a trailer in the uk?
If I'm correct on the above then you could just fit a single, 13p socket, use whatever wires you need and cap any unused ones off.
Obviously remove/tidy as required.
) it seems like quite a good idea as far as not overloading things is concerned.Yes, back then the wiring, switches & fusing are heavy enough to directly run the additional trailer lights.You know how it is, all the cool kids are doing it…
To be honest I’m not totally sure I do either.
As @bricol explains (almost entirely for my benefit as I’m sure you already know what the relay does mr pony shoes) it seems like quite a good idea as far as not overloading things is concerned.
Having said that the lighting circuits etc. have been running the trailer socket direct for about 25 years without any obvious problem, so maybe it’s just extra expense I don’t need.
Decisions decisions…
...and add that rear fuel tank while the bed is off....your gonna need it.....
FWIW I owned a 1986 f-150 and then a 1989 f-250.
Your supposed to use one of these:He doesn't need the second tank. The tow bar is for a fuel bowser.
I converted my trailer to LED as I was fed up with sorting dodgy bulb connections from badly sealed lights.Yes, back then the wiring, switches & fusing are heavy enough to directly run the additional trailer lights.
Incandescent no less, so if your trailer is LED, you should be fine.
Does it work? If so id leave itMy Freelander has a towing relay, because the previous owner was too tight to buy the proper box
Now I have a capable diag, my choice is do I remove the scotch locks and tidy it up, or do I remove the lot and fit the proper unit?
I think I’m with bob, if it works I wouldn’t do anything with it until it didn’t!My Freelander has a towing relay, because the previous owner was too tight to buy the proper box
Though I really can’t see that scotchlocks are a good idea. I know they work but damaging the insulation has got to be asking for trouble if they need to come off again. I suppose most of the people putting them on don’t have to worry about that…
Not that I’m foreshadowing grief on your land rover kayos, I’m sure it’s nothing insulation tape won’t fix when you deal with them…
Scotch-locks are a botch job. It's not a question of if they fail but when they fail.My plan was to rejoin the wires, but as @Bobupndown says, if it works, leave it alone
I have been in the area wiring a proper reverse camera in the tailgate so the scotch locks annoyed me when I saw them
I’ve been molesting my American pick up to deal with some issues- mainly rust related, though one of the non rust related tasks is sorting out the tow bar wiring. It’s a bit messy, it’s got at least two too many sockets, all three of them a bit crusty and wiring that already looks like I did it in places! I’d tell you if I had honest I would!
So the pick up is a 1998 Ford F-150 and came with a factory tow bar when it was built four score and seven years ago…
This has a main wiring connector which deals with the rear lights and trailer socket.
I’m doing my best impression of someone who has a clue so any advice is greatly appreciated…
