Cobbler
Codger bodger
- Gloucestershire UK
I read that as lube!I'm guessing you like tube?
me tooI read that as lube!![]()
Got a service bulletin here, regarding float heights and fuel levels, but can't be bothered to read it right now.....How do you do Amal concentrics?
Handy stuff, is tubing.I'm guessing you like tube?
Not just me then!
me too
See ? The concept is even understood by the most primitive of peoples.....Say tubing to a Sparky and they'll think your talking about conduit.
See ? The concept is even understood by the most primitive of peoples.....![]()
From what I can see so far it's just a s**t build by an imbecile with no clue.Sounds like it's hit a kerb on the right side and all the extra leverage has bent the frame![]()
Looks like there's no provision for axle articulation, so the first bump in the road that only one rear wheel went over may well have done the same thing.Sounds like it's hit a kerb on the right side and all the extra leverage has bent the frame![]()
Well . . no. Drawn by those with all the ideas, but none of the skill to actually do itThe illustrations in old manuals really are little works of art, all hand drawn and coloured by skilled people.
View attachment 527478View attachment 527479
Many trike conversions have a rigid rear, which is one of the many reasons that most trike conversions are utter garbage created by shaved monkeys without the first clue about suspension geometry, handling, weigh distribution, traction, welding etc etc.Looks like there's no provision for axle articulation, so the first bump in the road that only one rear wheel went over may well have done the same thing.
Must be horrible to ride?
Anyone around in the 80s and built/raced Tamiya Grasshoppers and Hornets will understand the limitations of the setup.
I concur,Many trike conversions have a rigid rear, which is one of the many reasons that most trike conversions are utter garbage created by shaved monkeys without the first clue about suspension geometry, handling, weigh distribution, traction, welding etc etc.
