lotus 30
classic car enthusiast mostly lotus
- caldicot south wales uk
WM 325 TYPE 1 M8 thread on the feetThat’s like mine, also was my fathers. Must get some new feet for it sometime, been saying that for 30 years![]()
Last time I had a look, some years ago, the old ones were well seized. Must remember to give them a soaking.WM 325 TYPE 1 M8 thread on the feet
) a cut in half RH orange vice handle knob.Well, I tried to remove the old foot, heated it up came for a bit, then the lug broke off the workmate, so it’s permanently unajustable now, unless someone local can tig it for me.I’ve just checked & yes they are M8 thread. Googled workmate feet & these came up, can’t see why they won’t do, local Screwfix has 5 sets in so I’ll use them if I can get the old ones out.View attachment 527216
Bummer I am soaking mine they are locked solid thats the trouble with steel long term in ally. it won't weld I don't think, the frame is actually crap ally. Mazak castingWell, I tried to remove the old foot, heated it up came for a bit, then the lug broke off the workmate, so it’s permanently unajustable now, unless someone local can tig it for me.
Can you use a bit of bent over a tad angle iron pop riveted to the leg to make a foot if you can't get things welded ?Well, I tried to remove the old foot, heated it up came for a bit, then the lug broke off the workmate, so it’s permanently unajustable now, unless someone local can tig it for me.
i used mine as an extra work bench, 1200x 600 plyboard with a 40x40 baton screwed down the middle
A lot longer to type than doSounds like drill exercise on Full Metal Jacket![]()
But I've killed a steel based frame version, which I had purchased many year after my fathers one came home.....That’s like mine, also was my fathers. Must get some new feet for it sometime, been saying that for 30 years![]()
Thats a rare mate tools the original before B&D bought into it it Ron Hickman a millionaire I believe over 30 million were sold and Hickman got 3% . It is the one I would like to have in the w/shop just for the history and Lotus connection thanks for replying.View attachment 527280
I’ve a couple of these. The original Ron Hickman design. The top laminated timbers are rather substantial!
Would that low temperature ally solder repair it. Has anyone used it much? I only have a blowlamp is it ok? I’ve seen it on the web & discussed on here, but are yet to speak to anyone that’s actually used it.Well, I tried to remove the old foot, heated it up came for a bit, then the lug broke off the workmate, so it’s permanently unajustable now, unless someone local can tig it for me.
I've used some that I bought from a Scanidavian guy at a kit car show many years ago. USed with a BNQ blowtorch on an Aldi gas canister. I'm pretty impressed with it. The surrounding metal gave up before the joint did when I made a test piece to abuse.Would that low temperature ally solder repair it. Has anyone used it much? I only have a blowlamp is it ok? I’ve seen it on the web & discussed on here, but are yet to speak to anyone that’s actually used it.
