Ross365
- UK
Perhaps there is some confusion about "penetrating" oils? None of them can get through into a rusted and seized fastener, despite claims from the like of WD manufacturers to the contrary as there is nowhere for it to penetrate.
Is it your belief then that there is no degree of porosity in the rust through which low tension liquid can permeate? I thought that one of the reasons why rust goes on and on is that moisture (water) can permeate through rust, otherwise, rust would be a protective oxide, like the chromium oxide formed on stainless steel? Whether there also may be some "tips" of the threads which don't fully plug with rust, and so leave tiny pathways for liquid to get down is also a consideration. Does a semi-crystalline material like rust weaken (crack) when wetted; some materials do that; try cutting a thick-walled glass tube without wetting the initial scratch and see how much easier it snaps when wetted
. Wetting the tips of cracks in many materials is a game changer.I imagine that some engineering companies (oil platforms?) have studied all this and know the reality of the situation, but their info seems not to have penetrated its way in to the public domain and so pretty much all of this thread is just a collection of personal views but lacking data.
And certainly, the application of heat very often works, for obvious reasons; no data required there!
