I'm surprised by the bosch ones not being any good, their consumables are usually good.
Or just whack the screw in then back it out till the jacked up board lies flat & set it in again, way faster than piloting & suitable for 99% of stuff unless you're doing something that needs to be super preciseThey are indeed a good bit of kit.
Drilling a clearance hole in the upper mating piece, however, is still good form. That's what a lot tend to overlook, when just blasting a screw into things.
I only tend to break out the impact for stubborn tasks, or when installing frame fixings & such. Drill & driver are still my preferred combo for most tasks.
I got a mixed bit set a few years back (none impact) that came with a little case, which is OK. But I'll steer clear of their impact bits!As was I. The flat bit tip bent like buggery when I tried removing a stubborn flat head screw, & that was just using a handheld bit handle.
Can't fault their drill bits & suchlike, but definitely wouldn't recommend their driver bits.
Think we probably have a different threshold for rough & readyThat method works too. One of my quirks is that I can't do that though, unless it's some rough & ready task which doesn't need to last.
. For me it's more about the timber & the quality of the screws.I've had a tic tac box of dewalt impact bits, they've been decent to be fair. I'd get them again.
i got 15 boxes of them 4 quid a box they hold up real well screwing drywall hardened screws day in day out
What I doOr just whack the screw in then back it out till the jacked up board lies flat & set it in again, way faster than piloting & suitable for 99% of stuff unless you're doing something that needs to be super precise
I use DeWalt impact bits, but bought the Erbauer long series bits and they're fine.They're sh*te.
The Erbauer bit set which Screwfix sell are good. They occasionally have them on offer at half price.
light weight i have 7@Endeleus what brand do you use?
A 12 volt multi tool will be an eye opener if you've never had one.
You're right about the impact drivers though, it's so much easier than using a drill driver, I have three now...
I buy their 1mm slitting disc s , excellentThey're sh*te.
