Ahh, that's good to know.Don't be silly you can not knurl a carrot . .......................................... .
You might surprise yourself if you bought some nice quality hand files...and more time than I have left !
Fly press!Don’t hold back John, let’s have mashed spuds from the drop hammer, or fly press if no drop hammer.
That's useful info, I will have to file that away...Check out hoffmann group, they do some decent files.
Acme threaded parsnips and 1/4 inch partially parted small swede. It might be a bit difficult putting a thread on peas & tomatoes though .Vegetable broth . Doing a bit cooking video with a machining twist .
Always gets a laugh , we all need to laugh more .
Cut a thread lefthanded and righthanded on a morse taper using an eight start thread counter for both threads ..it will look knurled if you use a smallish threadDon't be silly you can not knurl a carrot . Now a parsnip that is different .
Any important screw cutting like bronzeWhen you think about it a soft material like veg is good to practice screw cutting. You are not going to break anything and its fun.
We did the same when I was learning fine furniture making and renovations . Most times a piece would be fully made in a reasonable carcassing pine & ply wood & also with recycled veneers steamed off old furniture .Any important screw cutting like bronze
.I do in plastic first just to check settings
I
I think the beauty of turret mills is really in the relative speed and ease that you can make setups to use the flexibility it has.Although not a heavy duty machine cant deny the design is ridiculously flexible in how you can set it up
Only 2....Needed a T-slot adapter for my big rotating Vice on the bridgeport , already had slots in the base but they were 25mm and needed to be 16mm luckily had some 25mm accurate bar so just needed to mill to size
View attachment 522403View attachment 522404
Found a use for the second mill drilling and tapping into the base I knew 2 mills was necessary
View attachment 522405View attachment 522406View attachment 522407
Yeah i'm in denial 3 is probably the right numberOnly 2....
