Misterg
- North Wales
...the timing setting is 5 degrees atdc.
Our '71 bay was the same. You need to have the original distributor for it to work - there's some sort of additional vacuum advance thing going on.
Finally someone with some sense. The only way to check and set ignition timing is with a timing light. You set the max advance, check the idle advance, then re attach the vacuum pipe. Doing it by ear is asking for melted pistons. You may have done it and got away with it, you may have got it right, but the method is flawed.It isn't really possible to properly time an unloaded engine by advancing or retarding at either high or low speeds and watching for the rpm drop. The mixture is different unloaded which has a totally different timing requirement for maximum rpm. That's why vacuum advance exists. If the mixture is set incorrectly, so will your timing if it is done by ear.
The advance curve could also be wrong and you'd then be on a path to engine destruction.
So many supposed cooling issues turn out to be a poorly tuned engine, especially the timing. I've watched many people spend heaps on cooling system "fixes" with no success until they finally listen to me.
) turbo-charged, injected engine in my Lancia . . .no.That engine probably had a distributor that had a double vacuum advance /retard unit originally?Interesting comments re the timing positions,my air cooled VW,has a 1971+ engine with the AH code,even has a female diagnostics socket! A USA engine possibly California,the timing setting is 5 degrees atdc. Never heard of it,presumably to reduce emissions,runs awful at that position probably going to waste fuel ,not save the planet,it runs sweet at 10,as others have said adjust by ear and feel,no lumpiness and quick pick up on throttle response.
Wouldn’t know how to recognise one.That engine probably had a distributor that had a double vacuum advance /retard unit originally?
I remember my old foreman adjusting the timing on a Bristol 410 with a newly rebuilt engine, 500miles later it had a hole in a piston !Finally someone with some sense. The only way to check and set ignition timing is with a timing light. You set the max advance, check the idle advance, then re attach the vacuum pipe. Doing it by ear is asking for melted pistons. You may have done it and got away with it, you may have got it right, but the method is flawed.
Look at the vacuum advance unit, it probably has 2 vacuum pipes going to it? Think they are NLA.? One mod that air cooled VW owners do is to fit a readily available 009 distributor which does away with vacuum advance, from memory the timing is set to around 30deg before TDC at 3500 RPM . Better performance and economyWouldn’t know how to recognise one.
Wouldn’t that stress the big ends?Look at the vacuum advance unit, it probably has 2 vacuum pipes going to it? Think they are NLA.? One mod that air cooled VW owners do is to fit a readily available 009 distributor which does away with vacuum advance, from memory the timing is set to around 30deg before TDC at 3500 RPM . Better performance and economy
The 1600 in our '71 bay had thrown a rod when we got it.can’t remember a single case of big end failure.
As a young apprentice I owned a split screen type 2 that had loads of end float, I measured it then “ adjusted” using shims only to find the crank was locked solid! What I didn’t realise was the main bearing itself was floating in the crankcase accounting for most of the end float . Ended up having to rebuild the engineMy missus Beetle had a valve guide bobbing up and down with it's valve once and about an inch of crankshaft end float!
The thing still run though.
Like I said, lack of oil or oil changes will wreck any engine.The 1600 in our '71 bay had thrown a rod when we got it.
She got a refurbed engine from that place on the A1 in Highgate.As a young apprentice I owned a split screen type 2 that had loads of end float, I measured it then “ adjusted” using shims only to find the crank was locked solid! What I didn’t realise was the main bearing itself was floating in the crankcase accounting for most of the end float . Ended up having to rebuild the engine
I just had this same discussion on a FB group. I put up how to properly time them. A supposed expert for the cars it was about thinks that doing it by ear is the way and that's what most others were saying. I'll just let people melt their pistons.Finally someone with some sense. The only way to check and set ignition timing is with a timing light. You set the max advance, check the idle advance, then re attach the vacuum pipe. Doing it by ear is asking for melted pistons. You may have done it and got away with it, you may have got it right, but the method is flawed.
many manufacturers before the 60s didn't specify a dynamic timing value as timing lights were uncommon at the time. Only a static value was given and the advance curve was expected to be tested on a distributor machine.You can't use a timing light to set dynamic timing on some Triumph engines - there is no spec to work to.
Unfortunately that's a very big assumption. Most original distributors are worn and new ones usually have questionable advance curves.All this assumes the dizzy is suitable for the engine.
Indeed, if you look at an original Haynes manual for the humble mini you will see around a dozen (from memory) of differently curved distributors. So anything aftermarket is pot luck.Unfortunately that's a very big assumption. Most original distributors are worn and new ones usually have questionable advance curves.
