Lots of good things have been happening in the last 10 days
New headlights are great, one needs the beam levelled.
Built in sidelights are not wired up yet.
A mate gave me a new headlight bowl and headlight mount so that will get fitted when I fit the relay kit.
Fuel - now seems to be good, I’m still fine tuning the mixture and tickover but it’s very close.
Ignition - I think a lot of the unhappy running was caused by a dirty joint inside the distributor. The “working as a temporary fix” condenser got mounted properly.
Points got cleaned at the same time and the engine ran very sharp for the first time ever.
Nice !
I also borrowed a mates timing light and found the timing was set at 30+ when Haynes says under 10 degrees
It got reset to 10 but isn’t as crisp so I suspect the sweet spot is somewhere between 10-30.
I’ve been told modern petrol needs more advance - anyone have words of wisdom?
A mate had several new “original factory 1 piece exhausts” so I claimed one.
In the factory they are fitted then the back axle is fitted. It will be fun trying to fit it on ramps !
He thinks it’s for a Cortina Mk2 estate but it’s close and I'm sure it can be persuaded to fit, shame it’s a slightly smaller bore
The car got some exercise running from South Wales to Midlands and being used as nature in intended
I'm confident that's not it (I tried doing that years ago on another car and it didn't work well)
Engine ran very crisp last week when the timing was advanced 20* past the timing marks, it's now set correctly using the marks. I'll reset to 10* extra when I get my timing light and compare..
Top guesses are my mates timing light is faulty or front pulley / front casing has been swapped for something with timing marks in a different place![]()
A quick photo in the Welsh valleys just to show it didn’t rain for the whole journey home
Never a dull day![]()
Fizzy could do with that wood nomad .Already in my van many thanks!Fizzy could do with that wood nomad .
Trust your hearing as soon as it moves to picking up you'll be likely at it's best . If you can get hold of a large vacuum gage 17 to 21 inches of mercury depression in the inlet manifold get it to the biggest depression you cannot get better .than that.
One issue - the timing marks now line up but I had to rotate the distributor, a casting lump now makes it very difficult to tighten the distributor base clamp which makes me think something isn't the way it should be
The distributor is driven by a dog which engages on the skew gear which is a separate part. Easy to remove/adjust/refit on an A series engine , just need a 5/16” UNF bolt to screw into the skew gear, rotate one tooth then reassemble. Been years since I worked on a B series but I think that is the same. As already suggested a vacuum gauge is a useful tuning toolDistributor fed by a skew gear? If so, it is a notch out.
B-series is a drive dog, on the end of a drive shaft, geared from the camshaft .Distributor fed by a skew gear? If so, it is a notch out.
www.aronline.co.uk
My preferred option was set to idle at around 2000rpm, advance till revs stopped then back off 100-150rpm. have a test.Most of my cars with clockwork ignition got timing set, once running, by twisting the dizzy in the direction of increased revs, until they started to drop, then back to just before peak revs.
I used to set the No1 to TDC then take the distributor out watching how much the rotor arm turned, turn it back by similar amount then replace it then set it by ear once the engine was running.Distributor fed by a skew gear? If so, it is a notch out.
