Careful how you grind those in, you could lose 1.6bhp at 8500rpm+ if it's not a good seal.This is the sort of thing I'm working on
View attachment 523269View attachment 523270
Just got to remember to check for valve seat distortion after dropping it in a bucket of boiling oil![]()
I think the first set of valves I ever lapped in were on a Jaguar mk10 which after assembly need shimming , again the first time I ever used a set of feeler gauges ( remember them?) and a micrometer.
I probably won't ever be lapping another valve in my life again.Try fine..
I will be lapping valves next week. I've got a Perkins 4.248 to rebuild, someone ran it out of oil, it seized cylinder one big end ripped the rod cap off and pushed the rod through the block. Purchased a pattern short engine probably made in China it will be interesting to see how it lasts.
I like Perkins engines they are well made with UNF threads that clamp well without needing massive torque figures. And no silly stretch bolt'sLast Perkins engine I did from that era was a 4108 - fitted into Bedford CA vans and Transits of the time - done one years later that went into a Narrow Boat.
They sell the 400 series engines under the Perkins name but they are made by shibaura. They are great little engines. We run several 2.2 four cylinder models.Perkins at Peterborough been owned by Caterpiller for over 25yrs now - they don't make small engines now...
Yes I think perkins own them.shibaura...?
Had to google that - Japan...?
The old Vibro centric , used one many timesThis was in my dad's tools that came my way, no idea if he used it in anger or just bought it on a whim at a car boot.
I may give it a check over and see if it runs.
Ok so. The seat sealing on the exhaust valve is not important on the compression stroke? Without precise accurate data of temperatures on all the components under operating conditions of your application, and tons of F1 level testing with this, your eliminating nothing, only adding variables. You’re talking about things you can’t measure with any degree whatsoever of accuracy. Anyway, I see where this is going with the attitude so il say no moreWell I wouldn't want the inlet valves to be red hot - the exhausts? not that important. Ultimately the valves will just grow, the head and seats will move and deform. But to eliminate what you can makes sense to me, otherwise why bother trying to make your race engine better than anyone else's. You carry on having the shivers, I build race engines to win, not fart about at the back. Sometimes these tricks don't work, but I've never had a catastrophic failure, I have mostly made progress though.
It’s also application dependent too based on the design of the block and material, a cast iron inline 4 will see basically no distortion with a head / torque plate, an alloy straight 6 bmw I’ve seen 4/5 thou of ‘egging’ without one. The thickness of the plate ‘should’ be tuned to give the same distortion as tests made with a headAs I understood it, its more to do with the distortion from the bolts, rather than the actual head. Some engines you can see polishing around the areas where the head bolts are, with honing marks still visible around the rest of the bore.
Heard of some race engine shops using heated oil, using plates with galleries in to circulate the oil to create thermal distortion too. I guess with race engines on the limit, every teeny, tiny, bit helps. But for engines where the head bolts drop into a ladder under the block, so no distortion around the bores . . . ?
I suppose it's a little extra you can charge the customer for.
For one of our highly stressed machines, we do machine with a substitute component bolted up to create the same effect as in use - seems to work, certainly reduced the number of failures/increased service life.
