Vixerfixer123
- West midlands
Hi folks,still having trouble with my 3hp sealey.it will pump up to around 70psi and either trip the thermal motor switch or the breaker in the board.its had 2 new capacitors,new thermal switch,fresh oil.checked the check valve,had the lid off and cleaned reed valves etc.i took the belt and the motor will run no problem.what doesn’t seem right to me judging by info on youtube,is that the run cap is 65uf and the run cap is 60uf.i was led to believe the start cap should be around 3 times greater than the run.im out of ideas now
