Normally the suspension unit mounting plates are welded to a box section (it's dimensions depends on trailer capacity/loadings and the length depends on required wheel clearance) to form an axle beam, the axle beam assembly, is then welded to the trailer frame.All my parts have arrived to start building my trailer. My concerned is the 8 hole steel plate will extend out from the chassis by 25mm allowing for tyre clearance. Is that what should I expect.
