Great! When can he start?
Thats always one of the things to look for, open the back door to see if the factory joint is still presentI've put quite a few of those arches in.
The thing to note is that it's obviously one panel where the original was two, a lot of carltons have the overlap in the door shut just blend away with filler which I think looks awful. With your skills replicating the original should be easy enough and very worthwhile.
but there is not a lot about
Do you think that's down to the various scrappage schemes causing many of these to get ended prematurely?Im not having much luck finding the other panels to help with the repairs
I think its pretty standard for most manufacturers panel wise, the cars are old and worth very little, the supplies dry up as they don't press any more so its only what new old stock is floating around,Do you think that's down to the various scrappage schemes causing many of these to get ended prematurely?
Good spot but Im not on facebook, any idea of the location?Not sure if any use to you
Diddly squat mateHow you getting on, Blobber. Much progress?
