Will find out whether Chinese battery holder (Aldi) to Japanese Mitutoyo vernier is doable on Tuesday.Did you buy a new one and sent the older one back? Didn't you?
I got some of the Norwegian equivalents, and they've been really useful. Being able to gently lower things is a big plus - the cheaper knockoffs don't seem to have that. The price is certainly ouchy though!An early Christmas present to myself after a particularly rough year.
A frivolous purchase, but something I can see coming in handy.
Wanted some for a while but they are normally obscenely overpriced IMO - but caught these as a refurbished offer, and had a voucher which brought them down to just obnoxiously overpriced.
They do seem well built though.
How about across the width? That's how I move 8x4 sheets.It’s not the weight but size and arms not long enough to grip opposing ends so you have to pinch it from the top and my grip never seems to last
You can lift it that way but struggle seeing where you’re going and can’t get it through doors without lowering. This is just so much easier.How about across the width? That's how I move 8x4 sheets.
Can you tell whether it closes up small enough to carry sheets of steel? Whenever I buy steel 8x4 sheets it's a struggle to get them from the door down to where I store them, and it's gripping them that's the issue.I bought one of these recently after struggling moving full sheets of plywood around. It’s not the weight but size and arms not long enough to grip opposing ends so you have to pinch it from the top and my grip never seems to last where the board is intended to go.
I used the gripper yesterday for the first time and one handed lifts to wherever I want the board were a doddle. £14 and it’s a bargain, just wish I’d gotten one much sooner.
I use Kennedy Clamps for stuff like that - a trick I learned from the Welder-Fabricator where I used to workCan you tell whether it closes up small enough to carry sheets of steel? Whenever I buy steel 8x4 sheets it's a struggle to get them from the door down to where I store them, and it's gripping them that's the issue.
I'm pretty sure mine won't be able to grip an 8x4 sheet of steel to lift it.Can you tell whether it closes up small enough to carry sheets of steel? Whenever I buy steel 8x4 sheets it's a struggle to get them from the door down to where I store them, and it's gripping them that's the issue.
then reach over the top of the plywood and grab the handle, with the sheet of plywood going under your arm.
Yes, I can see that. I'm 1.98 m (6'6") so I'm more likely to have problems from lifting it too high.That only works if you are fairly tall, otherwise you are dragging it along the ground and knocking the corners out on any obstacles.
Board lifter from the top braced against your shoulder allows you to get it much higher off the ground IME.
Yes, or a bit of ply I guess. I have a few old suitcase trolleys that my parents used to use before they upgraded to suitcases with integral wheels, and I have thought about modifying one of those. I need to be able to move the sheet sideways as there's only a narrow gangway between the cars. I'm not sure I buy steel often enough to make it worthwhile, though.Sheet of emery in the jaws to aide grip on metal.
OOphs , think why they were refurbish sales ??An early Christmas present to myself after a particularly rough year.
