Vixerfixer123
- West midlands
Sometimes trip the one in the main unit and sometimes trips the one in the piggy backed unit.just tried the compressor and does the same.welder works fine on the 3 pin plug
Breakers are all c typewhat are the breakers are they a b type 16 amp and its the mcb,s that are tripping or the rcd my welder and 110 transformer will take out a b type mcb on start up needs changing to c type to stop the inrush current
It’s a sealey 170amp,but the same happens with compressor aswell,so must be my wiringis the welder transformer based
I will post a pic shortlydoes the welder work in a low setting ?
what compresser is it have you got a pic of the plate on the compresser so we can see the power it will be taking
might be worth taking the covers off the fuse boxes and posting a pic so we can cheak the wiring
also post a pic of the plate off the welder as well
Yes, BUT:Sometimes trip the one in the main unit and sometimes trips the one in the piggy backed unit. [...]
which breaker? mcb or rcb/rcbo?
Is it tripping the MCB or RCD?
if its your job luck dont enter in to it
Some times you get lucky and get things right
was a guess in the dark as not a huge amount of info to go onif its your job luck dont enter in to it![]()
