EViS
- United Kingdom
I've decided upon the following (cheap) setup, however prior to hitting the 'buy' buttons, is there anything I am missing to begin spraying?
Stanair 14CFM / 3 HP Compressor
3/8" Hose (incl. BSP fittings)
Iwata AZ3 1.8mm Gun (7.5 cfm)
Do I need any other connectors between the gun/hose and comp/hose?
Is a regulator at the gun necessary? If so, which regulator would fit?
Do I need a water syphon? If so, how does this connect (i.e. do I need more hose?)?
pva worked quite well.
