Smallfry
HE's Spartacus.
- Kent UK
As outlined in my recent other thread, my Renault Master cut out, and would not restart.
Got it home last night, but had a look this morning in between the rain showers. First thing was to check the camshaft belt wasn't broken, but its fine.
Could not find anything else obviously wrong. There is an inertia cutout switch which operates in even of a collision, and that is fine.
These had a rubber/plastic primer bulb in the fuel line, which is used after a filter change. They double as a non return valve. These are notoriously unreliable, and split crack or pinhole, allowing an air leak, and causing the fuel in the line to return to the tank, which will cause no start after engine has been stopped. There is no lift pump, either mechanical or electrical, and the setup requires the high pressure pump to feed itself, but generally if the leak occurs while the engine is running, the engine will stay running unless really bad.
I noticed that there was no fuel in the clear feed pipe, so pumped it back up with the primer bulb, and after a bit of cranking the engine started ! Which is good. I stopped the engine, to see if the fuel would gradually return down the pipe, but at the moment it is staying where it is. I have tried starting the engine again, which it does, but only after a fair bit of cranking, so I suspect this may have something to do with it.
I connected the van up to my diagnostics to see there were any clues. It threw up a few codes, but all marked as Not Present, apart from one, which has been there ever since I have had the van.
What I wanted to know for now though, was about the list of codes displayed. They are in a drop down list, so is the last occurring fault at the top of the list, or at the bottom ? Or are they random ? They are NOT in numerical order.
i gave him the set of injectors i hadnt long pulled out of it so he could have them refurbed becasue it was going to need a set, and gave him a new fuel filter, priming tool i had made, new tank sender unit, the remaining new injector pipe and a new rail pressure sensor...that surely should have been enough of a hint that this needed more than fresh diesel...but he still took it away thinking it was going to be a relaible car.
