that should give you a better idea ,,, its just a starting point , but keeps things really easy to makevery quick sketch
well Ill look forwards to the pics , its nice to see how other folk tackle things ,,,Haha that's a pretty decent quick sketch, you're definitely a man of many talents!
I've just realised if I reduced the box section to say 40mm then the 10mm plate would have fit inside the pusher plate u channel that wraps around the beam and been an almost perfect fit but no point changing that now I've got some coming for £9 so I'll do what you're suggesting with the side plates and just use an extra short section of the u channel as got plenty left and that'll help reinforce the rocking around the rod pin if pushing a log with the tip of the plate accidentally instead of it being up against the beam.
Makes sense beefing it up since got a +10t cylinder so might as well make the most of it!
That's where a cheap 240 volt chain saw comes in handy to chew away a lot of wood without hitting any metal then lightly tap with a 2 pound hammer once the pressure is off the wood .More than a single split on anything other than straight grained wood, will jam at some point, as a bit suitably knotted hardwood will jam even the biggest splitters.
Then you'll do a lot of cursing as you try to unjam it. If a sledgehammer doesn't work to knock the jam off, it's surprisingly awkward to extract a knife with a log jammed on it and spin it around to use the ram to push it off.
All the demo videos you'll see off commercial splitters, will be showing how easy it is to split some straight grained pine.
You'll never see them demonstrating on some knotted hardwood.
I wouldn't worry about hardfacing the knife. Bucket edging is ideal, but a suitable bit of flat mild steel will split fine. It'll likely bend eventually though.
No because the rods would glow lol. Think they're 2.5mm and running them at ~100a.have you got your welder turned up full ?
Yea I've been putting a decent bevel on all the edges when prepping and it's not all tight and flush most have at least 1mm gap since not perfectly cut with a chop saw. I've been grinding down the first couple passes and blending them into the following passes since it doesn't need to be pretty and would say it's getting decent penetration based on the look of the back side so definitely won't fail.start doing a wee bit of prep on your welds and think about leaving a gap ,,, farmers push things up tight for welding , fabricators leave a gap for penetration ,,,, dont worry too much about the whip and pause thing , worry about penetration . try the cut thing , then try a joint with a gap and look at it too ,,, nothing wrong with running a grinder over a joint to clean it before adding another pass either ,, most pipe welds are done that way and thats by folk who weld for a living ,,,
Based on the pictures, I do not agree.Yea I've been putting a decent bevel on all the edges when prepping and it's not all tight and flush most have at least 1mm gap since not perfectly cut with a chop saw. I've been grinding down the first couple passes and blending them into the following passes since it doesn't need to be pretty and would say it's getting decent penetration based on the look of the back side so definitely won't fail.
Have ordered some 3.2mm 6013 as these 2.5mm are only really good for tacking/light work.
that sums it up ,,,, but I was still edging on polite ,,,Based on the pictures, I do not agree.
I would be grinding the welds back out, and trying again.
I mean you're looking at pictures taken with an old phone with bad lighting plus they're mid weld as I did multiple more beads after, they might not look good in your opinion but they're not meant to be Instagram worthy or require approval from across the AtlanticBased on the pictures, I do not agree.
These might have been better ordered before the job started. As for your 130 amps are they real amps or oriental ones!Have ordered some 3.2mm 6013 as these 2.5mm are only really good for tacking/light work.
once you start hanging things from a quick hitch four or five feet of leverage and some rams and blades etc the weight soon adds up and the load on the weld gets quite serious quite quickly , maybe a couple of webs in a few places or the likes ,,,I mean you're looking at pictures taken with an old phone with bad lighting plus they're mid weld as I did multiple more beads after, they might not look good in your opinion but they're not meant to be Instagram worthy or require approval from across the Atlantic
I appreciate the feedback either way, most of them I have ground out and redone the pictures don't show the full day's story.
