Jim Davey
R H Davey Welding Supplies Ltd
- Southampton
That might be the problem. The CK20 has quite a small diameter hose pack and very narrow coolant pathways in the head. I’ve even seen this issue present itself with the higher duty CK230 which is still a 20 style torch with bigger hose bores and larger coolant passages in the neck and head.
It would be worth you measuring the coolant flow (just disconnect the red hose and point it into a measuring jug, run the pump for 15 seconds and make a note of how many millilitres of fluid you captured. Times the result by 4 and you have an litre per minute figure to work with. Best o get with a 25’ CK230 is about 0.9 lpm, I’d not be suprise if you got half that.
The lowest you can set threshold for the coolant flow monitor error warning is 0.5lpm. You realistically have a couple of options, get a torch with better flow capacity (WP20 style torches are woeful in this regard) or turn the coolant flow monitor off altogether and rely on coolant temperature monitoring instead (which you can set lower for extra safety (default setting is 70 degrees)
I did have the coolant sensor replaced under warranty on one of my machines that was showing a flow fault even though I set the mon flow to 0.5lpm and measured a steady flow of 0.9lpm down the red return hose. It is possible you have a faulty flow sensor (as far as I can see it is a sealed unit, so no way to adjust or calibrate it) and I don’t know how accurate they actually are.
Anyway hope this helps, if you need any more assistance I can be contacted via email at jim.davey@rhdaveywelding.co.uk
Thanks
Thanks
