50 seconds is more like it, usually, it's not drag racing. Half, or more fill should be ok, and provide a substantial improvement in stiffness, but see below.Which reminds me of John Whitmore, who had to race with the big boys.
Mind you if hill climbs are only 10 seconds long, drag racing (where there is no coolant system) fixes may be appropriate.
I need to remove a chunk (10mm plus) off the top of the block, and the head studs are being moved from the cast in, er knobs? To where there is simply a cast surface, hence not enough metal to hold a stud, let alone provide a stiff enough flat surface. I have wondered about inverting the block, cleaning and preheating and then pouring half an inch of aluminium into the (now top) of the jacket. If it were to stay in place it should do the job?I'm curious. I've known people who have run blown A series engines on nitro with just ARP studs. What sort of power output are you expecting?
All this block work is likely to substantially weaken the old mini block, hence looking at ways of returning some strength. Power wise I'm looking for 200bhp as a starting point.
I must say I have gone off the "cement" pouring option, simply because drilling through it is likely to be a nightmare, and will epoxy provide a sufficient "guide" to stop the drill from wandering?
