I started with gasless, then went to gas, then got the tig so swapped my gas for argon and put gasless back in the mig...but now ive bought a new mig (again) and a 5kg spool of solid wire as i have a few things to make that just dont make sense to TIG...plus ive bought another land roverThanks for reply yeah my welder can take a bigger reel if need be ! I mainly weld gasless as opposed to gas as it’s plug in dial the settings and go no gas bottles and setting gas to think about ! Or I use the stick welds
Never been able to find it in any of my local storesJust get Lidl flux core wire it works well
I just use gasless but can go gas as the welder does both ! You have to weld the Land Rover then lol I’ve an old 67 beetle but unfortunately it doesn’t need welding apart from a body mountI started with gasless, then went to gas, then got the tig so swapped my gas for argon and put gasless back in the mig...but now ive bought a new mig (again) and a 5kg spool of solid wire as i have a few things to make that just dont make sense to TIG...plus ive bought another land rover![]()
Nothing needs welding on the land rover at the moment, but it's a land rover so it's only natural there will be rust...that said, I have yet to get the silly covers off for a proper lookI just use gasless but can go gas as the welder does both ! You have to weld the Land Rover then lol I’ve an old 67 beetle but unfortunately it doesn’t need welding apart from a body mount
I would also add what made a difference (in my mind anyway!) was to use a 1mm tip and red liner in the mig lead and gun which let the wire flow through more easier (no judder) which I think was caused by the knurled wheel make small divots on the wire even though the tension was very low on it.
