The_Yellow_Ardvark
- Going Away.
Does is work?
Does is work?
I knew you would say that as soon as I hit post!Which one?
Does the lego one actually work as a game boy and play games on it?![]()
Alas not
Which one?A pointless device then!
Practice makes perfect, and they look mighty fine from where I'm sitting.Two bowls out of five attempts is not that bad... maybe? If it wasn't for the magical effects of 80 grit sandpaper, it probably would have been 0 out of 5! Perhaps I should stick to boxes and tool chests!
That'll be the sandpaperPractice makes perfect, and they look mighty fine from where I'm sitting.![]()
That'll be the sandpaper![]()
I'd be happier if I'd spent most of the time turning and a bit of sanding at the end. With these bowls, I spent much more time sanding than I did turning (as I made such a mess of the turning and the only way I could see to recover was to use coarse sandpaper for a long long time). Also, the other three attempts (two of which were on really lovely bits of wood) ended up as firewood as the mistakes were too big to be able to deal with even with sandpaper.Which is all part of the job, so I am not sure why you are not justifiably proud of those? They look like something I would love to have gracing my house.
I use Abranet on my Mirka sanders, it is night and day difference when the sander has extraction.My wood turning friend swears by abranet sandpaper.
It may seem expensive but it lasts for ages because it doesn't clog up and works really well with dust extraction.
If you cant source it then Festool do a Net version of their own sandpaper that I think is pretty similar in quality to the Abranet stuffI use Abranet on my Mirka sanders, it is night and day difference when the sander has extraction.
