DD is so worthwhile a watch for most power tool repairs, learnt so much from his YT videos and put some of it into practice.I hadn't - watching now and it looks good. Thanks![]()
Knowledgeable, easy to follow and giving, bless him.
When looking to drill holes your existing cordless should manage, its a good tool and is rated, so I'm not sure what's going on with it, why you are experiencing the lack of grunt.That's also what I was thinking, it was just about alright for a TV bracket and shelves on interior walls which I think were concrete? But was awful for 8x60mm holes into brick recently.
I wondered if an SDS was/still is a worthwhile purchase, or if I was just doing it wrong or expecting too much.
As good as your drill is, nothing really beats an SDS + for most domestic and commercial work and a SDS-Max for jobs like demolition work, although some SDS+are capable of light chisling and chirping depending on quality of bits.
I shifted to Makita cordless tools a number of years ago, no real regrets and learnt how to rebuild their batteries or decent copies.
I do have some exceptions to my cordless tools so for example my cordless multi tool is a Dewalt, it was on an offer so purchased it, it was bare bones that didn't bother me, I have a number of Makita batteries so use a battery adapter for the Dewalt.
I have and use a couple of corded 15+ years Bosch jigsaws still in use.
I recently purchased a corded 240v SDS+ drill. I really wanted a Makita, couldn't afford new so was prepared to buy 2nd hand.
My logic being it can be more worthwhile buying 2nd hand branded then new and crap, but nothing corded and right voltage came up.
Plan B, do some research and prevaricating and did I, silly really, its an SDS+drill, not that important.
In the end I settled on this.
There are a couple of missing design features on this model I have become use to on other drills but I can live without them or adapt for my needs.
Recently use it to punch a 22mm hole through a 12in thick brick wall with no struggle but I am using quality bits after getting advise off these forums.
So your Makita packs a punch or should but an SDS + will get you through most things, especially a corded one but so should a 18v SDS+ cordless.
A BHP451 I bought recently. I have refurbished a couple of these before for our Men's Shed.
They are a beast of a drill and will bite back if the bit jams. If we need to use a big tenon cutter this is the one we use.
This one is mine and it will be getting a refurbishment in the future.
A bit bigger than a standard duty Dhp 453!
Regarding the rubber strips on them - they can be glued back down using super glue. Just need to degrease everything thoroughly with thinners.
There is a raised plastic stop on the inside of the battery holder of the drill where it slides, sharp chisel, utility knife, remove the stop make it smooth.My newer batteries dont fit my BHP451, only older ones. Have you found that.
I don't know if it works for all Makita tools and newer batteries but works on mine.
Check this out.
Makita do have different battery platforms but they are radically different in design and performance.Oh ok, thats worth a look. I just know this and pick up one of the older batteries rather than a newer one.
Why did Makita do this? Is there differences in the batteries?
I have newer Makita drills, but for heavier jobs, use the DHP. I reckon it is one of the best 18v tools Makita have made.
Then Makita introduced their Star System, a method of charging communication between battery and tool/ battery and charger but also allowed for the larger LXT amp batteries they introduced.
Sure, I'm not sure it is tool monitoring, their star system is more to do with the charger and the battery.The newer star batteries have a better BMS pcb that monitors the voltage on every pair of cells and adjusts charge to each pair to charge the battery evenly.
It also cuts off the output of the battery if any pair of cells goes below a certain voltage to prevent over discharge of the battery.
I think this is around 3.4v but its hard to measure because the voltage bounces back up after it cuts out.
I have had numerous LXT star tools apart and so far I haven't seen anything to indicate tool monitoring.
The 3rd pin is there and sometimes connected but there is no pcb or extra components in the tool itself. Just a trigger switch and the motor.
On brushless tools the 3rd pin is connected into the sealed motor control unit. It may do something but as far as I can see all the work is done in the battery itself.
I had to dig these out, see photos.Just had a look. Yes, you're right, it's the 5 amps that dont fit. The 3 amps do.![]()
Those are great links @Agroshield, must give it a go.See:
and for red Makita:
See:
and for red Makita:
Thanks @qwakers - job done!oh and fit this chuck...
fits all makita lxt drills and is a better design than the one for the older dhp drills.Makita 763252-1 Keyless Drill Chuck 13 Bhp448/ 763252-1 from Spare Parts World
DESIGN : Industrial design for long life CAPACITY : Accepts bits up to a 1/2" shank DURABILITY : High quality steel construction for added durability CONVENIENCE : Easy to install for added user convenience INCLUDES : Drill Chuck BUY NOW OVERVIEW ABOUT Makita Drill Chucks are engineered for iwww.sparepartsworld.co.uk
