I'm not suggesting incinerate but the application of a blast of heat directly down the chuck jaws might release any loctite used and then a smack with an impact driver.Never needed a impact driver or heat. I would advise against heat. You'll melt the casing long before it does anything useful. The chuck won't be that tight, the smack is to break the friction.lock from the base of the chuck to the drive, nothing else.
That's a shame.That redbanded chuck is crap. Just took one of a drill. 1 year-old been used 20 or so times and is slipping and jamming
I have one of those , and one of the brushless ones ,,, the brushed one is very very low power so dont be expecting too much , it will get things done eventually but you wont be cutting rebar with it all day ,,, the brushless one is as good as any cordless tool without spending silly money.Rain stopped play outside today (and I'm waiting for yesterdays plastering to dry before I can paint it - then I watch the paint dry..)
Next up, BGA452 grinder, working fine but was said to be low on power compared to mains grinders. New brushes fitted when I'm doing the other tools.
Super quick and easy to do: pop out dust covers on the hand grip, undo flat-head brush holder, swap brushes
If anyone has any helpful info about Makita cordless tools feel free to add commments here rather than start a new thread @Turbo![]()
I always get the corded one out for masonry.the hammer on all battery drills sucks, its not meant for that. buy a sds if you need to drill masonry..
Ive one and its mighty ,,,, not a thing to be taken lightly at all , yes its heavy but it works well. Its not sds heavy hitting but its not an sds , I go for the Hilti when I need that , it will put the odd rawl plug in thoughTangentially related, since we were talking about drill chucks, and it is an 18V LXT... I have known and loved a few different LXT tools, but the DHP486 combi drill is making me miserable.
I don't know if Makita got it wrong by making it compact, or if I'm not holding the thing right, but it strains the hell out of my hands and rubs/pinched them too, I just can't keep a solid hold of the thing, even with the side handle.
As well as that, the power I was expecting just doesn't seem to be there. Torque is no problem, it doesn't seem to lag at all, but I have to really lean into it to get anywhere in masonry, which adds to the fatigue. I was expecting it would match or beat the ~40 year old made in West Germany Bosch it was replacing, but doesn't feel like it.
Is there user error here? Is there something inside in particular I should be checking to replace?
an sds is a different beast ,,,, but when things get that serious Im looking for one with a cord on it.That's also what I was thinking, it was just about alright for a TV bracket and shelves on interior walls which I think were concrete? But was awful for 8x60mm holes into brick recently.
I wondered if an SDS was/still is a worthwhile purchase, or if I was just doing it wrong or expecting too much.
On a non-SDS machine, the quality of the bit can make a difference.
I am a fan of the blue Bosch multi-material bits for use in a cordless. On hard stuff, it can help to pilot drill with a smaller diameter first.
I have a Makita 18v LXT SDS drill and it’s very capable. Not quite on the same level as my Bosch corded but very close.That's also what I was thinking, it was just about alright for a TV bracket and shelves on interior walls which I think were concrete? But was awful for 8x60mm holes into brick recently.
I hadn't - watching now and it looks good. Thankshave you seen dean docherty on you tube , he does a lot of makita stuff
