johnakay
make Record no DMD24A & DMD 28 not sure which.
got a wobble on my chuck.
what has happened is that while drilling (using forstner bit) oak wood it got jammed in and struggled to get it out.
obviously turn the drill on wobble wobble.
try as I might I cannot rove the chuck.
there's no slot in the main body so it cannot be driven out.
there is how ever what look like 2 flat sided on the shaft that looks to me for spanner use.
thinking this will be a screw in type.
the rotation of the drill is clock wise so to me this should undo whacking it with chuck in clock wise.
it will not budge at all or using a ball joint remover and that doesn't work.
instruction manual tells my nothing inc drawing on how it is fitted.
it look to me it is one whole shaft.?
before I do anything drastic I need advice from those who know.
you tube videos aren't much help either.
