Onoff
- Sevenoaks, UK
You're repeating yourself, you know.![]()
Sorry, thought I was posting in Codger's Corner!
If you have hot water radiators you could plumb it into the system and dry the logs out that way. Only partially joking . a moisture meter is the best way to check the water content . I was told that felled logs dry at the rate of1 inch (inward ) per year so to give them a couple of hours is not going to reduce the moisture content of the inner log.Shelved racks. My plan, eventually, is to replace those two log racks I have with one larger rack, including a shelf or two. Planning on making it from 15mm copper pipe & standard solder fittings.
A lot of the Woodsure & Accreditation hoopla's seem to base a lot of standard calcs around the joules of energy produced by wood at 20%.20% appears to be the magic number:
I also found out from their data - that to get the equivalent heat energy of 1000L of Kero takes between 6-8 Cube of dried logs.
So, unless you have access to timber instead of buying in, a wood burner would be a lot more money to run & a lot less convenient, and take up a lot more space - than my oil system![]()
When it’s sleety, dark and cold outside, and you’re sitting with a glass of whisky in front of a crackling fire, you don’t care so much about the costingA lot of the Woodsure & Accreditation hoopla's seem to base a lot of standard calcs around the joules of energy produced by wood at 20%.
I ring Sadie the log lady….she even stacks them….its obviously a business expense as our holiday cottages have log burners!When it’s sleety, dark and cold outside, and you’re sitting with a glass of whisky in front of a crackling fire, you don’t care so much about the costing
Buying split logs would be a last resort - all year round I have my eye out for timber. You can never have too much firewood.
My daughter has a log burner, and yes a real fire is very nice.When it’s sleety, dark and cold outside, and you’re sitting with a glass of whisky in front of a crackling fire, you don’t care so much about the costing
I season my logs outside for two years in ibc crates, just thrown in so the air can get around them, fully exposed to all weather. Then in September, after a dry spell, I put enough into a weather tight shed to last the winter. Then a barrow full at a time into a log basket by the fire. Works very well for me.
Yes, green wood is far worse to burn than rain-wet seasoned stuff.If after seasoning for a couple of years it makes no difference to the moisture content if the logs then get wet in the rain. The internal cellulose structure of the wood shrivels up as it dries out. The only reason you need to keep them dry as they season is to stop them from rotting. Dry wood does not soak up water anything like as much as a live or freshly felled tree. They get wet/damp and dry out without affecting the "moisture content".
If you have space just pile em high in a shed….a friend of ours is all wood, hires in a processor now and then, they just get rattled in an old cattle barn, with Yorkshire boarding, and turned now and then with a tractor bucket! Shed is split into 4 bays. Wood is bought where ever is cheapest on the day!I cant find IBC cages cheap enough to justify the number I need. I burn around 9ton of wood each winter so could do with a few really!
