We all get 1 step forwards and 2 steps backwards some daysHad a chance to put in some more hours this week but wasted a lot of it by doing one particular job twice! Got the inner sill all cut and then a replacement piece of metal made and welded in. This went well but when I went to fit the outter sill, it wouldn’t fit.
I then broke the cardinal rule and reversed it. I measured once and cut twice! Disaster, as I somehow managed to cut 10mm more than I should have. I then wasted half a day trying to fix my cock up before realising how ridiculous it looked having a 10mm strip welded on to the bottom of a panel so I had to force myself to cut off all the work I had done as well as all the spot welds to make it right.
Next job is to fabricate the end bits which are going to be a real pain. View attachment 511860
Years ago, my brother drew one of those on the white board in my office. I cleaned it off, but you could still see it very faintly in the background for years!Haha, yeah was trying to make him leave that rocket there but he refused
Let's hope this one doesn't show through on the new wrap, lolYears ago, my brother drew one of those on the white board in my office. I cleaned it off, but you could still see it very faintly in the background for years!![]()
You mean using a tig as a spot welder? It's interesting and I haven't used it much but it could be good ......consistency is helped by a spot function on the machine and ability to set duration of weld. There is argument about the technique the video above shows - some say modify the cup to allow gas to escape, and use a blunt tungsten 1/16" below the tip of the cup - have a look what this guy shows....I'm interested to know if anyone has used this method before for the spot welds .....
I don't look at these threads much, so new to this ........I'm interested to know if anyone has used this method before for the spot welds rather than plug welding?
www.frost.co.uk
I've had no mentors apart from YouTube and Forums, unfortunately.
