I just make it straight in the bottle, makes it go further if your giving them awayMade some sloe gin this year for the first time
Never made it before, see how it works out.
What do you use to store the concoction in? The jars I used are a bit cack, when you turn them over every day or so, the rubber seals leak.
Stick a bit of cling film on first or fit 2 sealing rings.The jars I used are a bit cack, when you turn them over every day or so, the rubber seals leak.
Weird...added 1.3lb of sugar early and some nutrient and the fermention started again and it was quite vigorous. A few hours later and its stopped?
I'd be tempted to give it a bit of a shake up, and then see what happens.
Sounds like you could have 'shocked' the yeast, I would take a sample e.g. jam jar and add a small amount of some fresh yeast to see whether it will re-start. If it does you can them add this to the main batch after a day or so.It's been 7 days since I added another 1.3lbs of sugar to my pear wine. After an initial surge of re fermentation the same day it stopped and nothing apparent for a week.
So the initial recipe calls for 3lb per gallon or 2lbs 3oz for a dry wine.
I'm at 4.3lbs for the two gallons. So that's 2lbs 2.4oz, near enough imo the 2lbs 3oz imo for the dry recipe.
Shall I just rack into two demijohns?
I'm tempted to add more sugar to eke out every % of alcohol I can get.
Following the "sloe gin" - "vodka" thread of this post with interest...![]()
I don't need flavoured spirits - I need a still...
Googled "liebig condenser"...
Now in my mind - I am fabricating coil things with 4.75mm brake pipe...![]()
Yeast doesn't like sudden change be it temperature, acidity sugar, etc - the cell walls can rupture and the yeast dies.Not heard of shocking the yeast, what's that then, how?
So from my calculations and approximations based on the recipe, the dry version with 2lb 3oz (1kg)/ gallon (4.54l) had the potential to produce 12.7%ABV at 0.996 finishing.
However, with your half sugar you're at about 7.5%ABV (ish)...what does it taste like?
