knoba
...break a leg!
- Sussex, England
Last year my old van wanted "extensive" welding for the MOT. The vehicle has a chassis and is not of a monocoque design. The job involved; completely cutting out rusty areas, fabbing accurate new panels for butt jointing, tacking every inch and then seam welding them in. Simples...
...not quite! I was getting a bit fed up with it!
So... for welding the non-cosmetic sheet sections (floor panels for example), the MIG was set to approx - 110Amps, 7m/min & 12l/min.
Metal thickness is 1.2mm... butt joints. Wire was 0.6mm. Gas was Argonsheild light.
In using the mig on these settings the machine is quite obviously laying down a lot of power and wire. It's laying down a foot of weld in about 3 seconds with excellent penetration & no blow throughs.
It seemed as though the high wire speed feeding into the weld was stopping the high (amps/volts) from blowing it through (combined with a high torch travel speed, and thin wire). What I liked most about the technique... it did an excellent job; produced almost flat weld beads, phenomenal penetration, used barely any gas & took very little time to do.
Does this technique have a name?
I was congratulated by the MOT man (a welder himself) on the soundness of the; welding, job & vehicle! - no advisories.
Metal thickness is 1.2mm... butt joints. Wire was 0.6mm. Gas was Argonsheild light.In using the mig on these settings the machine is quite obviously laying down a lot of power and wire. It's laying down a foot of weld in about 3 seconds with excellent penetration & no blow throughs.
) high power technique is not suitable for use in critical or aesthetic applications, but it didn't stop me playing with this ratio (machine settings + material + user input) the other way around, in replacing the vehicle's exterior side lower quarters.
