- Birmingham
Not sure what the risk assessment was when they built the new factory to build the Metro in the late 70's, but I think the fire requirement were covered.
The sprinkler system was powered by an electric pump with a back-up pump in case that failed and a diesel pump in case the electric went off and if all else failed, there were 2 big tanks on the hill above the pump house that could gravity feed the sprinklers for a minimum of 15 minutes.
Sidenote: every column in the building had a hose reel and when the inside was being fitted out the contractors would use them when core drilling the floor, the downside was the water flow would be detected and set off an alarm in the works fire station causing the fire trucks to be turned out, notices appeared on every hose reel and contractors warned they would be thrown off site if caught using them.
went to a pub on a callout and a cable was bright red on the end in the fusebox and stinking a bit . the clown chef squirted over everything in the leccy cupboard and bu.ggered the lot up
