That looks rather tidy, to my untrained eye.![]()
The cable ties dont match the grey wire, or the earth for that matter! Those different sized boxes might offend ones OCD
Haha, you beat me to itProbably better to have fixed it on the wall instead of the floor?![]()
the 2 on the left should have been lowered and both inline otherwise ok! Those different sized boxes might offend ones OCD
looks to be 16mm . it hasnt been connected to the supply yet by the looks could feed the 1st block from supply with 25mm tails and take the link out between the blocks if its only 16mm and put in 25mm if its not a tt system the earth wire feeding the db s should be 16mm not 10Don't know what and how heavily loaded everything is, and I've heard of diversity, but could the tails you have linking the two Henley blocks become overloaded if they are the same size as all the other tails?![]()
They are clipped down, only by chance thoughshould be using mains tail glands as well not grommets https://www.electrical2go.co.uk/fus...CNWQhnNpiwRT-euUu2gGMJnwbvCRJdvAaAuyqEALw_wcB bet you wished you hadn't shown it now![]()
there not to secure the cables its to stop fire breakout if someone doesn't tighten the cables up properly
