brightspark
- yarm stockton on tees
bought mine for 75 quid not working ,it needed rewiring and one new 3hp motor been working fine now for over 10 yearsThey're awfully good aren't they?![]()
That was a steal. Paid a good bit more for mine around a similar time. Only had one problem, the little valve that sits between the cylinders (something to do with off loading I think) rusted up and the spring failed. I contacted Clarke who couldn't have been more helpful. Sent me a new valve (FOC) and drawing to show how it should be mounted according to some service bulletin or other. Apparently they were fitted wrong (too low) and so moisture built up and caused corrosion.bought mine for 75 quid not working ,it needed rewiring and one new 3hp motor been working fine now for over 10 years
Already know about that mate.they will be set slightly differentIs it worth mentioning the slim chance that they might just try to cut in together and trip the circuit![]()
and fit a shut off ball valve between or quick disconect couplings so you can still use them separatelyyou simply connect the air outlets together, however you fancy. its not hard.
Sorry for the questions folks but i ain’t too clued up on this subject,but do i need to wire the 2 pressure switches together or do i run em separate?
each compressor has a none return valve fitted between the compressor pump and the tank thats it nothing else needed
