Vixerfixer123
- West midlands
Hi folks.i am linking together 2 hp compressors to run a 10 gallon pressure pot,but my question is if the pot is rated at 150psi,how will the pressure be regulated to stop the pot exploding?
Yeah I realise that.so is it just a case of adjusting the 2 compressors so the both both together are not supplying more than 150psi when both running?Your two compressors will still only supply whatever the compressor pressure cut offs / pressure relief valves are set too (Normally 10bar (140psi)).
I have a copper pipe air dryer on the wall,with 4 lever valves and a filter reg after that.Do either of your compressors have a pressure switch set above 10 bar?
Further, you will want a water trap prior to the pot. Just get one with a regulator.
What are they set to now? If they're set to 140psi now indervidualy, then they will still only supply 140psi linked together?Yeah I realise that.so is it just a case of adjusting the 2 compressors so the both both together are not supplying more than 150psi when both running?
One cuts out at 120psi,and the other is not running yet as it needs a start cap replacing.What are they set to now? If they're set to 140psi now indervidualy, then they will still only supply 140psi linked together?
So if both compressors cut in and out at roughly the same as stated above,the pot won’t continue to pressurise?linking compressors increases max flow, not total pressure. youll be reet.
only part that needs regulating is the output from tank to pot kept at 90psi . running the pressure up and down without makes it difficult to keep the media and air pressure ratio constant you end up chucking more media through than air when it drops wasting grit and not being as efficientif they're both cutting out at 120psi ish and the pot is fine to 150, I'd join it all up without regulators, you're going to need as much flow as you can get, the less restrictions the better!
tis possible as long as theres about 6 seconds diffrence on starting will be okIs it worth mentioning the slim chance that they might just try to cut in together and trip the circuit![]()
That's what I have on my twin pump compressor, but of course, twas designed that waytis possible as long as theres about 6 seconds diffrence on starting will be ok
i have one 2That's what I have on my twin pump compressor, but of course, twas designed that way![]()
They're awfully good aren't they?i have one 2![]()
