Hi there,
I’ve got an old MG ZS 180 I’m putting back on the road after 7 years.
I thought I would take a look at the front floor pans/jacking points which were looking very crusty (common rust point on these).
I’ve so far had a prod around on the drivers side and attacked it with a wire wheel expecting the worst, however the metal actually seems solid. I’ve had this platform of Honda/Rover/MG before and ended up with big holes in this area.
Just want some advice on what process I should follow. Baring in mind I don’t have a compressor, paint gun, spot blaster etc. I am a novice but I know that simply slapping on some waxoil from Halfords isnt good enough.
I am mainly unsure about at what stage I re-apply the lost seam sealant, and also which seam sealant to use?
I have previously used brushable seam sealant from a tin before and I don’t like it at all. Very messy. Should I use PU sealant such as tiger seal instead?
As for the process, this is what I am thinking…..
Treat the area with hydrate 80
Prime (epoxy prime?)
Stone chip (or under seal?)
+ seam sealant somewhere in this list
Any advice much appreciated
