julianf
- devon, uk
This -
You see its got a crack in the outer ring?
I forget quite how these work, but i think the outer ring keeps the sealing "rubber" thing under compression, right?
This has been like this for years, and is not leaking, however, i want to remove all the stuff above it, and i fear that will take tension off the ring and cause it to leak.
Both pipes either side of the fitting will not move, but the fitting itself is one of these -
I dont know if you can remove the middle section on them without moving the pipes themselves?
Either way, its going to be no fun.
Or can i just pour some sort of resin stuff all over it, and not think about it further?
Again, its not leaking now, but i just fear that messing about with the stuff above it is going to make it leak.
