- Birmingham
An interesting fire extinguisher that leaves no mess, the Fire safety stick seems to have been adopted by a lot of big companies.
This again.Ok for carrying in a vehicle I guess and better than nothing in an emergency.
But you have to get too close to the fire for it to be effective so I can see an inexperienced user getting injured trying to use it.
With a water, foam or powder extinguisher you can stand well back from the fire and control it.
@The_Yellow_Ardvark - any opinions?
Thread drift, but I’ll be in the UK later this year, recommendations for a couple of CO2 extinguishers for the workshop please Ardy?This again.
Buy a unit that is bs, eu etc approved.
Indeed nice to have in the car if it doesn't get damaged by frost?Ok for carrying in a vehicle I guess and better than nothing in an emergency.
Too small for any car fire.Indeed nice to have in the car if it doesn't get damaged by frost?
Powder makes your car rust?Too small for any car fire.
Smallest size advised is a 1kg dry ABC powder.
Foam is better but freezes, apparently now there are foam ones that don't, but they're expensive and have short shelf life.
Luckily my car doesn't catch fire every year.
Powder does not rust your car, the damp it sucks up will.Powder makes your car rust?
I think if your car is on fire the last thing you worry about is rust!
As a race and rally marshal I've had a lot of training in dealing with car fires.
Normal practice is to use the powder one to put out the fire unless it is a liquid fire, then you use the foam.
For under bonnet fire you either spray the powder from underneath the engine or crack open the bonnet and spray through the gap. Never open the bonnet fully as you are giving the fire more oxygen.
I worked for Chubb for a couple of years in the early 90s when I first quit going to sea.Thread drift, but I’ll be in the UK later this year, recommendations for a couple of CO2 extinguishers for the workshop please Ardy?
I tried asking dad who worked for Pyrene / Chubb for 40 years but he’s getting on a bit and out of touch![]()
Powder is hateful stuff to clean up if it is used inside. Once saw a boat where a powder extinguisher had been used…still been found 5 years later.Powder does not rust your car, the damp it sucks up will.
All foams have a freezing point. No, the lower freezing points one are not more expensives. Just a lower rating. They have the same 5 year life,
...and this ^^^ is the best thing to do, remain calm.I can only remember one time when I have used a fire extinguisher in anger, in the canteen at the BBC. Used to pop down there for a smoke (err, yeah, few years ago this was!) and one of the bins was itself smoking furiously, like as if it was just about to burst into flames. I remember the shocked look on the faces of those present and the fact that everyone in the room froze solid.
I strolled over to the wall, picked up a fire extinguisher and filled up the bin with it. Then just wandered off. These days you'd be offered PTSD counselling and told to fill out a report before getting fired for not having the correct up-to-date training....
At least hey had a boat.I worked for Chubb for a couple of years in the early 90s when I first quit going to sea.
What type of foam are they using these days in extinguishers synthetic FFFPs since the AFFF ban is comming. Is there also a plan to ban it in the big fixed systems that are using AFFF.
No more than normal, less I think, due to the motions of the car.Is there an issue with powder extinguishers 'packing down' when stored in a vehicle?
Seem to remember something about race car systems where all the bumps and vibrations packed the powder down over time which reduced their effectiveness?
I'm assuming the same applied to your normal powder extinguishers?
