Indeed, each one has its uses, but if you have the time a vertical is still miles better than the other options at cutting slabs, heads, even tube if you are careful. In an ideal world have one of each with 3 bands and slow and fast speeds. After my lathe my fast/slow running band saw is the best tool in my workshop.I wouldn't want to use a vertical band saw for cutting anything other than sheet or small stuff. Unless it had an automatic feed and then you'd be talking about an industrial machine. Last night I had to cut several pieces of 1.5" x 3" and I just let the horizontal machine run and do its thing while I got on with other jobs.
I don't know if the older ones are better as these all seem clones with the same castings..... but later ones do perhaps have a few more pennies shaved - so it's quite possible.Yeah £180 does seem steep for it, but it sounds like you got it up and running alright and it's worked out for you.
Is it still the case that the older ones are better built?
I keep seeing ones that are either enormous:
Or just miles away. I did toy with the idea of making a DIY donkey saw till I find one, but I keep thinking I'm better off with the angle grinder.
Yeah that's in budget, but it'll require some tidying up here and there.Here's one pretty local to me at £80, so they do exist (just never when you're looking)....
Metal cutting bandsaw
Metal cutting bandsaw, age related surface rust and marks. Good working order. Comes with 3 spare bladeswww.facebook.com
Interesting, someone made loads of these and they were sold by various sellers -Warco, clarke, Sealey - any more? They are all identical as far as I can see, mine was made in Taiwan or so the label says. Spent an hour scraping the surface rust off the vice etc, ordered a pair of bands from the guys in Treforest last night, even cut a piece of tube with the blunted band that's in there last night.Keep looking. I just did a quick search and found this one 20 minutes away from me. Motor looks like it has seen better days, and if I wanted it I'd probably start with an offer of £50.
Bandsaw is one of the best machines in the workshop just set it up and leave it to chew through , I can cut metal in the evenings with hardly any noiseI wouldn't want to use a vertical band saw for cutting anything other than sheet or small stuff. Unless it had an automatic feed and then you'd be talking about an industrial machine. Last night I had to cut several pieces of 1.5" x 3" and I just let the horizontal machine run and do its thing while I got on with other jobs.
Agree, how I made do without one for so long I'll never know. I even used my vertical to cut the lobes off a mini cam so I could machine it round the other day, saved hours of bump, bump, bump on the lathe...Bandsaw is one of the best machines in the workshop just set it up and leave it to chew through , I can cut metal in the evenings with hardly any noise
I have the Startrite 24 - s - 10 meaning it has 10 speeds.
I run neat cutting oil on my 6x4. Not the best photo but may provide inspiration. The 'tank' was welded up from square tube, bit of car brake pipe and fittings and a little air-line on/off tap. Blade cuts better, lasts longer, but it is a little messy.Interesting, someone made loads of these and they were sold by various sellers -Warco, clarke, Sealey - any more? They are all identical as far as I can see, mine was made in Taiwan or so the label says. Spent an hour scraping the surface rust off the vice etc, ordered a pair of bands from the guys in Treforest last night, even cut a piece of tube with the blunted band that's in there last night.
Might take the advice and remake the tin stand, but don't hold your breath. One mod that would be worth doing, if I didn't have a vertical saw would be to make a table and clamp to convert it to upright, would be easy enough methinks.
Has anyone bothered making an oiler? Is it worth it?
Mine a Clarke 4 inch cut ( second or third hand to me ) came with the original steel footplate & mounting screws etc . It was when setting it up that I tipped it over backwards damaging the wheel casing and ripping out the cable stress reliefs. GRW's vice table sounds good , perhaps not so if you have a long flat sheet where you cannot see the cutting line easily . What limitations have you found GRW?There’s already 2 threaded holes on the ‘bottom’ guide when it’s upright to screw a table onto.
Mines branded as SIP but it’s the same one
I can't say I've cut long sheet through the table, but no limitations beyond its just a small table of course, and the throat of the saw isn't large like a bigger bandsaw.Mine a Clarke 4 inch cut ( second or third hand to me ) came with the original steel footplate & mounting screws etc . It was when setting it up that I tipped it over backwards damaging the wheel casing and ripping out the cable stress reliefs. GRW's vice table sounds good , perhaps not so if you have a long flat sheet where you cannot see the cutting line easily . What limitations have you found GRW?
