Pete.
- Kent, UK
That does beg the question as to why then do you have the machine?
The machine is for checking and flushing them with cleaner.
Remove the spaces from that number:
I tbh would go for Chinesium ones on an old motor.
I have a test machine that does the same job as bob's that cost me less than having 2 sets of injectors matched and flow rate tested when sent away which I used to have to do, and it makes it a doddle to see if a injector is out of spec or stuck.That does beg the question as to why then do you have the machine?
Heh I flow tested the injectors out of daughters 207 as a matter of course while I was going through the motor. They were all ok though so went back in. The live data on Peugeot Planet doesnt seem as helpful as other oem stuff sometimes.Also check the NEW ones too before you put them in. I had one injector go down and then another. Replaced all 4 with new and as still having an issue convinced myself it was the coil pack.
It wasn't it was one of the new injectorsA pita diagnosing which injector on the 206 even with Peugeot Planet that I borrowed. Wasted spark system etc.
