Elliot 10m, the next job for it is machining the dovetails on a very worn Myford ML1, maybe in another 8 years.What shaper you got?
Morning or afternoon?Elliot 10m, the next job for it is machining the dovetails on a very worn Myford ML1, maybe in another 8 years.
Yes, vacuumed as soon as I finished, I hate machining cast iron.Make sure you clean the bed thoroughly after doing that!!!
All that for an earth strap?Quick little get out the *&#! Job for my father...he managed to break one of these and they are only supplied with 1 per unit...priced them up and the minimum pack of 20 cost nearly £500 plus the obvious wait for dispatch...
Off cut of 316 and about half hour including set up for the taper and I've just been told it fits perfectly. M6 thread, 9.5mm total diameter and a ballache of a taper to clock in as its only 8mm long and the part I was given to take measurements off was bent and mangled where it sheared off.
pretty muchAll that for an earth strap?
pretty much
Neat job!
Most folks would just use a spouting bolt an nut.
That little stud looks very much like a simple stainless steel sleeve anchor bolt used to fix into concrete or brick .not allowed to deviate from the drawing in any way...took long enough to convince the engineer that filling a 2mm gap with a 3mm packing shim wasnt going to work, id hate to see how long it would take to convince him to spend 500 quid on a pack of spare studs or even change the purchase order to include 1 spare per unit...used to work for them in a different department and they have some very strange approaches to engineering, nothing is simple and nowhere near cost effective, but they have some very good sales reps...i left when i became an apprentice in another factory, i was in college with their now head engineer of the department in question and he manages to be on annual leave for every important meeting, much like in college when there was always something better to do than actually learn how parts were made. the same engineer is responsible for changing the supplier of the stainless nuts that are used, and since that change there have apparently been a large number of issues with damaged threads on parts right across the department.
