Islander71
- West Scotland
After recommendations on here I bought one of the remarkably cheap AT1 VFDs off Aliexpress., and with help from a member have got it running my Wadkin wood lathe with remote switching and reversing sorted. The motor seems to be giving more torque than when using the original static inverter. When set for the frequency to be controlled by the unit's control knob it varies from the 20c/s to 65c/s which I've programmed in, but when set to be controlled remotely via a 10k potentiometer with wires to ground Vil and 5v, it will only vary between 20 and 42 c/s. Tried wire direct from Vil to ground, then to the 5v, and still only the 20 - 42 c/s. It has a 12v terminal so I moved the wire going to the 5v to that which has given me the 20 - 65 c/s. But now I'm worried that the higher voltage may damage the unit. Should I set it pack to the VFD's control or is it safe to leave it connected to the 12v, ViL ,and ground?
