Brad93
- Essex, United Kingdom
Have a small project for one of my customers.
Imagine a cylindrical tank about 2 foot deep with a conical bottom, heated to 70 degree celsius, full of gloopy plumbers flux. Incredibly corrosive to certain plastics.
They used to use a float which pushed up a rod, which moved a lever connected to a mercury tilt switch. This was operated at 230v and capable of carrying a considerable current for it small size.
It was all housed in a rather pants plastic housing with springs. Anyways the plastic broke down over time, springs shot off into oblivion. I managed to fit the tilt switch into a small metal enclosure however on first use it somehow arced out against the housing despite being in shrink tubing.
I'm now looking for a suitable alternative for fill control.
I tried a microswitch, unfortunately the force required to activate it was too much and the float doesn't have enough buoyancy to push the switch down before the flux solidifies over the top of the float rendering it useless. When it was working the pump was also coming on for 2 seconds, off for 2 seconds, etc etc which isnt going to do the pump any good.
Ideally we want the fluid level to go down 200mm then the pump runs till max, then drops 200mm again etc.
This leaves me with two options, only one of which I'm certain will work although it will require some relay logic i think to get it to do what I want.
Ultrasonic sensor, ideal as its non contact and should work acceptably off of the gloopy liquid flux.
or one of these. my only concern is the float getting bunged up with solidifying flux and then it not working. https://uk.rs-online.com/web/p/float-switches/4928946?gb=s
Anyone got any ideas? I can post some pictures today.
Can not have any plastic. Three phase plugs, cable ties, plastic cable glands - they all disintegrate and become brittle in the presence of this stuff!
