Bought something similar for well under 3 figures not that long ago. Hadn't been used much and the bead breaker ram was siezed. Squirted plenty air line oil up the hose and it eventually came back to life. As good as new now Labour intensive if your a tyre fitting business but fine for me.I you have a compressor (I currently used a small V2 Aldi unit), I purchased this style of tyre changer years ago second hand off Ebay, the only thing that can really go wrong is a piston seal or control valve or if it's not bolted down correctly chemical fixings for mine...
Also buy the extra optional bar for alloy wheels.
A brilliant bit of kit. Cheap even when new.
Sealey TC962 Tyre Changer Pneumatic/Manual Operation
Product Details Heavy steel construction. Pneumatic bead breaker. Suitable for use on most automotive/light commercial open centred wheels. Features additional air line coupling for tyre inflator. Supplied with standard tyre bar and PCL couplings. To prevent damage to the rims of the alloy...www.mccormicktools.co.uk
https://www.ebay.co.uk/itm/135551520829?_ul=GB&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338990947&toolid=10001&customid=eb:g:vms:eb:135551520829;{GCLID}&gad_source=1&gad_campaignid=1557785751&gbraid=0AAAAADmMgijTaLqfEisCDSq8aSCDNJdyS&gclid=CjwKCAjw6ZTCBhBOEiwAqfwJdx5CPnE3P9CnBOjzxXmYWAl7MhfRTllPizX4NxAgm5HKul8Teg3W8RoCsBsQAvD_BwE
I'm not after a pro machine - "a cheapy should do", Chinas finest manual type. There was another thread recently but I cant find it..
I'm aware it'll need a soft duck head for use with alloys.
Is there a better type for under £200?
Don't bother been there if the beads on tight that'll slip off rather than break it. They don't get in tight enough and push straight down somehow. Keep looking for the air operated type s/h as above.I'm not after a pro machine - "a cheapy should do", Chinas finest manual type. There was another thread recently but I cant find it..
Something like this?
Sealey TC960 Tyre Changer Manual Operation | eBay UK
Steel construction with manual bead breaker. Suitable for use on most open centred wheels. Supplied with tyre bar. TC963 Tyre Bar.Product Specification. Optional Accessories: TC963 - Tyre Bar for Aluminium Wheels.www.ebay.co.uk
I use one of these, not high tech but does the job.Bought something similar for well under 3 figures not that long ago. Hadn't been used much and the bead breaker ram was siezed. Squirted plenty air line oil up the hose and it eventually came back to life. As good as new now Labour intensive if your a tyre fitting business but fine for me.
Car tyres will still need balanced though
I upgraded my workshop one last year.
Bought a Corghi - as the last one was a Corghi and it lasted well - gearbox went in the end.
I bought a single phase 24" full auto one with three way helper arms for doing run flats this time. Plus I bought the full set of motorcycle wheel clamp adapters/pads as well.
I did have a bit of deal on it - but it was still big money... I don't actually sell that many tyres to be honest - I don't stock any now - mostly I buy them trade at local indie tyre bay and they fit them (even thou I got a brand new shiny tyre machine) - if it was not for the fact I got a decent wheel balancer with a good motorcycle adapter - I was thinking not to bother replacing my tyre machine when it pooped itself.
But I do change a few motorcycle tyres for myself and a lot for other people - as all local tyre bays won't touch bike wheels. If you bring me the wheels out of the bike and a tyres you got off the internet - I charge £22.50 a rim to fit including tyre disposal (plus valves/tubes/weights). Most bike shops wanna supply and fit - not just fit (who could blame them?)
I don't remove bike wheels here - well I will if you a kid on a moped/scooter/125cc learner bike and you pushed it into the yard with a puncture. But mostly these need tyres and I end up getting stuck with bikes in the workshop - till the parents of said teenager fund a new tyre. I do stock a few tubes for this job.
I also sell allot of sets of four tyre valve pressure sensors (mostly Fords) - and have the TPMS kit to live them up on other makes - program them. Without a tyre machine - I would be begging the local tyre bays to push the beads back to fit these. So I do need a tyre machine.
Buying in and stocking tyres and selling them fitted is low margin work - you gotta do allot of them to earn your money. Plus people will order expensive tyres and never come back to get them fitted. It is one of them jobs where it only works if you doing a big volume.
There was a time when 21" and 22" tyre changers were big machines - now they sell 25" 26" ones for cars and vans.
If you not gonna do too many tyres - a semi auto one will do - bigger inch wise you buy the better. Helper arms are must for run flats.
I am tight/mean - and I like secondhand stuff (because it is cheaper). But tyre machines get worked like a Blackpool Donkey on a hot summers day in tyre bays. Chances of finding one that is any good - is slim to remote.
I can get tyres off anything and change them with levers - but it is hard work and you gonna mark the rims for sure.... That is the downside of manual tyre changers - marking the rims.
That machine needs room all around it for you to walk the tire tool.Space, rather than cost, would be the problem.
I dont have fancy low profile tyres, they are plain 205/70/17's if I remember right.
Ebay doesnt throw up much locally. Anything I should search for?
there prety sh.it and flimsy i copied one and beefed it up and it was ok/ i got a decent proper bar for it as there sh,iteI'm not after a pro machine - "a cheapy should do", Chinas finest manual type. There was another thread recently but I cant find it..
We charge £25 to fit customer supplied bike tyre to loose wheel, not worth doing for much cheaper than that.
We also have a disclaimer about damage to paint, as careful as you can be there is still a chance.
Before moving our shop had probably £5,000 + worth of tyres on the shelf. Working out how much we actually made supplying and fitting them it wasn't really making any money at all so it's all order per job now.
Bridgestone are a great tyre but a swine to fit!.
Filling it with lighter fluid and lighting it up is faster I hear...I've been told that if you buy a tyre thats been stacked and squashed, it helps for seating and getting it inflated if, before fitting, you blow up an inner tube in the tyre to expand it and leave like that for a day or two.
ether is quickerFilling it with lighter fluid and lighting it up is faster I hear...
