Smouser
- Amesbury, Wiltshire, UK
Bottom Line Up Front:
I need two M14 x 300mm high tensile bolts—preferably somewhere in the UK.
Background:
A few years ago, I installed a 2" spacer lift kit on my Ford Ranger. As many know, spacer kits increase the angle of the upper control arms, putting extra stress on the joints. While in Thailand, I picked up some aftermarket UCAs specifically designed for lifted suspensions, but never got around to installing them.
Fast forward to last week: my Ranger went in for its MOT and came back with advisories on both sides—worn upper suspension arm bushes. Perfect excuse to finally swap in those new UCAs.
The Problem:
I got everything prepped, jacked the truck up, removed the wheels, and started loosening the upper control arm bolts.
Only to find I couldn't actually remove them. The bolt hits the bodywork and can't be fully withdrawn.
After watching a few YouTube videos, I realised these bolts are typically installed from the opposite direction—away from the body. If the bolt is installed from the opposite side the bolt can be withdrawn as it slides behind the body. So how did mine end up the wrong way around?
Here’s my theory: When I bought the Ranger new, the chassis rusted quickly (especially at the welds). I complained, and Ford agreed to strip and recoat the chassis. During reassembly, I suspect they installed the suspension while the body was off, mistakenly inserting the bolts from the wrong side.
Now, my options are:
Option 3 is the most viable. But after calling PartsPlus, I was quoted £110 + VAT per bolt - which seems absurd.
I am also annoyed with Ford for putting the bolts in the wrong way and I am not particularly keen to further support them by buying their expensive bolts. Their profit margin must be astronomical.
I did find some 12.9 grade bolts at A2Zfasteners and ordered them. However, after a week, there are no sign of the bolts, no communication from the company after numerous emails and looking at their Trustpilot reviews, it does not look likely that I will ever get the bolts
Luckily, I paid via Paypal so should get my money back.
So, the big question:
Where can I get two M14 x 300mm high tensile bolts in the UK at a reasonable price? Any suggestions for alternative suppliers or places to look?
Background:
The Problem:
- Lift the body (major job, not practical).
- Cut into the body (definitely not doing that).
- Cut the bolt in sections using a grinder, remove it piece by piece, and replace it.
