Smallfry
HE's Spartacus.
- Kent UK
I have an old (1972) Unimog, that is fitted with a similarly old HIAB crane that FiL had fitted in the early nineties.
It has its own hydraulic system, independent from the Unimog, apart from its pump being driven off the main gearbox. The problem is, that the main lift ram drops during operation. Not fast, more slow, but not not really slow. So, for example, I wanted to lift a ton bag of sand etc, I can position the arm, but by the time I have walked over to hook it up, it will have dropped 8 to ten inches.
With the bag of sand not too much of a problem, but if I were trying to lift something that would be easily damaged, it is !
I see there are a few knowledgeable people on here by Chismac's recent post, so what is the most likely place to be looking for the fault ? There are NO external leaks, so should I be looking at the ram itself, or the hydraulic block ?
The hydraulic block has two spare services, only four of the six are used, so could I swap the pipes over to one of these, or is it likely that the characteristics would be vastly different ? The block is one piece, and not a sandwich of slices
