I've made this one larger than needed and it'll be trimmed to fit on site. For the larger panels I originally cut them out in marine plywood so planning to use the plywood as my template.Would it be prudent to test fit the cut panels before doing any further work?
Getting some supplies together for the next phase which is tabbing the bulkheads...need some help from the collective.
I need a screw top container that I can use to soak my tools in acetone. Max tool width is 140mm...max length is maybe 25mm.
Idea is the save the tools in the container between uses.
Tupperware by another nameI use rectangular deep polyethylene containers available from fibreglass suppliers, they have snap on lids & are great for brushes rollers & acetone.
Mainly things like this...biggest is maybe 14cmx25cm.Can you clarify the tool sizes you want to store?
I think the seals are silicone which will get attacked by the acetone?Would this type of thing work
