MetalMonkey
- UK
Finest chinesium bush removal kit.
Does appear to do what it says on the tin.
That's interesting ermmmm..No real complaints. Fires up first time. It would appear the farmertec cyl coatings are not the best so buy with the intention of replacing the cyl at some.point with a decent one.
I am looking to buy the 880 or 3120 clone next. The G3120 has just been released so price quite a bit lower. Not decided which yet.
Indicating you drive it LIKE YOU STOLE IT!The last one looked like it had a quick pass of a sand blaster over it!
It’s amazingly noticeable when you get a shiny new, non-pockmarked screen isn’t it?
Especially noticeable with my Caterham – the screen is nearly vertical, so pretty much everything coming towards it, hits it full on, rather than being even slightly deflected by the air stream over it as with a conventional (modern) car. The last one looked like it had a quick pass of a sand blaster over it!
That price wants looking into ...Same in my Morgan, flat glass and almost vertical - just checked the replacement price, £1275.00![]()
Shirley, it is just a piece of laminated glass cut and ground to a particular shape.Same in my Morgan, flat glass and almost vertical - just checked the replacement price, £1275.00![]()
So make template, give to glass people etc...
(Same as I did for OJ the car).
Or find a local Plant/Agri glass fitter, as they'll turn up, measure, cut, and fit.Shirley, it is just a piece of laminated glass cut and ground to a particular shape.
Maybe worth talking to Ricky Evans Motorsport ?It’s a heated screen, and it needs it - no demisters!
Same with the Caterham - made in Scotland from the sticker on it last time. Replacement annoyingly doesn't work on a couple of wires right in front of me. Rather less then your price though.It’s a heated screen, and it needs it - no demisters!
(Never knew Morgan had gone that posh...
this is much more Morgan electrically heated windscreen in IMO )![]()
The other 2 measuring tools I found really handy for the kitchen fitting was a digital level and digital angle measure...I could then keep everything bang on level and vertical which really helped when it came to fitting the doors and the drawers..
