Daughter has no money ? I she eligible for a new boiler heating grant or financial help as the old boiler is now 12 yrs old & often come into the government warmer homes replacement schemes , My 39 yr old oil fired boiler was microbore and all piping was removed as it is not effective in getting enough water to the new double rads . All new 15 & 22mm pipes were surface run through the roof void ( we have a large bungalow) , where they did have to drill the walls there was very little mess on our two day old new carpeting which was easily sucked off by my heavy duty vacuum cleaner .Daughter inherited grannies house recently. Heating is knackered. It has a leak on a brass valve bit. Repair man says its not cost effective to repair. Its an ideal logic of 2012 vintage. It was installed during one of those campaigns headed by johnny ball that ripped off old people. The previous heating was the old back boiler type installed by council in 1984. Anyway it still has its original radiators and microbore piping.
Daughter has no money so I'm paying. What can I do myself to reduce costs. I suspect its pointless trying to keep the rads and pipes, nothing has been serviced or flushed ever. Can I just rip out the old microbore and put plastic or could the layout be different considering this layout was for an old system.
We have had to have two more boilers ( one every 12 years or so since it was installed as the life of the more efficient oil fired condensing boilers is a lot shorter than the ancient heavy cast iron and steel plate heat exchanger models . Changing the boiler & insulating well had seen us reduce from 1200 litres of heating oil, three times per year 3600 litres to just over one tank of 1200 litres ,
I got rid of the letter box in the door as well ,which also made a noticeable difference once we had an external mail box put on the outside wall
no thanks.
