To the left of the spring looks like a butchered rivet end, and it is also opposite another rivet at tge top of the picture.I have now removed both bearings. But, this little rivet snapped off from in that switch, somewhere. This minute thing could be what makes it scrap, my premonitions come true. I don't know where it came from on the switch, I suppose I will have to now takle the switch apart to try and find out,. Deeper and deeper I go.
NO he moved to Spain in 2019Could that bit be the illusive Higs Boson?
Up close, I would say that it is original and It acts as the stop for the contact on the switch.Could it be this stud was replaced in the past as it looks different / newer than the rest and that broken bit was stuck somewhere hidden until you took it apart then fell out?
I was under the impression that during start the switch was closed which let current into the start windings then, as speed increased, the weights opened which disengaged the switch and allowed current to the run windings. Well, it seems it was a waste of time reding about that the other day!The switch has nothing to do with the run winding.
It sounds like both then run and start windings go through the switch. Does it cycle on and off?
It appears that both caps are in parallel so the effective value will be the sum of the two capacitance values.Well, mine were both the same and the motor was running alright, with plenty of oomph. They connected like this, the blue wires at the top:
But it should cycle once the centrifugal switch closes.It could be that the run winding is not working.
The motor is running on the start winding and once up to speed the switch is doing its thing and switching the start winding off.
