Will there be a discount for forum members?
Make sure it's a new 5p coin unless you have a child they'd suit too!To gauge your size she'll need a picture of your hand photographed next to a 5p coin...
I decided to do the wiring in our new garage myself. I obtained an electrical permit from the town office and ordered a pile of supplies. I just finished the rough-in wiring, which the town’s code enforcement officer inspected yesterday. He’ll return for the final inspection after I finish installing all of the devices, which could take a while, since I'm not going to install the LED ceiling strip lights until after I’ve installed the plywood on the ceiling.
Here is the subpanel that I installed in the garage, which is fed from a 100A breaker in the 200A main panel in the house. I installed eight circuits, including one 50A 240V circuit, one 30A 240V circuit, and six 20A 120V circuits. The 240V breakers are GFCI, and the 120V breakers are all combination AFCI/GFCI (I'm not sure, but I think your equivalent would be AFDD-RCBO). I also installed an additional ground (earth) rod for the subpanel. Due to our cold winters (and unheated garage), I installed ‘hydraulic-magnetic’ breakers for all eight circuits, which are said to be more accurate than thermal-magnetic breakers over a wide temperature range. I didn’t opt for ‘smart’ breakers, since I didn’t see much need for them in the garage, and I already have more than enough ‘smart’ appliance apps to deal with on my iPhone.
The top right two slots have a plastic post that can be used to secure (for safety reasons) a back-fed breaker in the panel.What's the reason for the 240V breaker on it's own top left when there appears to be space for it top right.
I expect they wool be very chuffed.Tis erected, sheeps will be chuffed
Well once ive put the roof sheets on they wilI .
When are you putting the red light over the door?Tis erected, sheeps will be chuffed
Well once ive put the roof sheets on they will
