Jaeger_S2k
- Highfurlong, Blackpool. Lancashire
Should be something to suit ...I just need to find a vat big enough to submerge a complete MX-5 now...
It's only really in the context of continuously spraying it that it's worth considering.Re evaporation -
If we lived in a bone dry, hot climate, we wouldn't be battling rust anyway.
The evaporate will be so low down the list of concerns that tents and the like are madness!
IIRC, there are ideas about attaching pieces of zinc to cars in this book. The author was a Professor of chemistry at Salford, but I'm not sure about his proposals.I have wondered before -
A car is stationary for the majority of its life. If you could plug it in such as it was the cathode at all times, the electronegativity would stop rust forming.
If course sacrificial anodes on the sides of ships are the same but then you have fluid. I reckon, even with rubber tires, parking on a steel plate anode would give connectivity when you most need it (like when it's raining)
Think about how much quicker clothes dry on the line on a overcast windy day, compared to a very still sunny one.
I've been contemplating a shallow tray, big enough to drive a vehicle in, then a sprinkler system using pond pumps + 20/21mm uPVC pipe.
Rather than submerging the car, just a constant spray, recirculating the same fluid out of the tray.
Maybe not even a tray big enough for the whole car - could be one corner at a time?
I would think 2kg of water was about right for a pair of jeans after a spin cycle, more like 4kg from a hand wash.Your cloths maybe loose 2ltrs of water when they dry?
I would say that's a totally valid solution, as long as you're doing it, but it depends if you want to just leave it alone with zero intervention or not, and for how long.Still well within the scope of not worrying about it and getting the hose out once per day, and not constructing some sort of tent!
I really want to see a clueless vanlife youtuber use that to waxoyl their vehicle now...
The main thing is that if you set up a continuous evaporust sprayer under a car, you would need to pay some attention to the loss of water so it doesn't just dry out prematurely...
What are the bush housings made of?it's not aluminium
I can't see it's terribly critical, but just to avoid any misinformation, the original recipe was 40g of washing soda (=sodium carbonate), or 30g of caustic soda (=sodium hydroxide).1 litre water, 100g citric, 30g soda crystals.
I'm surprised there's any aluminium left.
Thought I'd give this a try, I usually just use citric on its own.
Test spanner. As found in the scrap
