gaz1
- westyorkshire
you can fit the lot as long as you dont connect up to the gas
you can even do the flue for the boiler
plumb all of the pipes in including the gas pipe only when it turns into the gas pipe that you cant touch it there after
remember if your gas pipe that you fitted leaks the installer will not pass your install but he may sort out the leak for you after all its only 1 join to the gas pipe its still a dry install until it connects up to the gas pipe
finding a fitter to join up will be your problem as some like the cream of the job
it went again and they sent someone out and the fitter criticised its been messed on with and not put back together properly . ohh yea it was one of your gas safe contractors that did it so now what
